Ok guys, I got my first check engine light tonight at 106,780 turns.
I heard the Roadrelay ding 3 time and the check engine light came on. The Roadrelay gave me a read out of:
Code 122 Inact. 3 Intake Manifold Pressure Circuit: Service Soon
I cycled the key 3 times to see what the code was for the Check Engine Light on the dash.
Got a P1693
Page 25-16 of the service manual give the P1693 (M) code on two seperat lines with an error of:
DTC DEtected in Companion Module - A fault has been generated in the companion engine control module.
Next one down same code
DTC Detected in PCM/ECM or DTC Detected in ECM - A "Companion DTC" was set n both the ECM and PCM.
Sooooooooo, Anybody got any ideas
I Hope
After reading in the manual, I am making an assumpton that the Roadrelay is telling me exatly where to look as the manual give the pressure circuit as an example.
21:05 Update ---- I have oil on the cross memeber and it looks like it is dripping from between the power steering unit and the vacuum pump static. Too late to work on it tonight as I don't want to wake up the neigbors. Will start her up tomorrow and check for dynamic leaking then.
This could be a sucky week. I was planning on heading home to Salmon, Idaho for Thanksgiving.
Got a P1693
