Just this past Monday (12/20) CEL came on and I posted here - see "Dreaded Check Engine Light - from the 20th.
Last night happened again. Had been running around a bit and stopped at work for 10 mins. Went through usual start routine, turn key & engine turned over normal but no start. With out cycling key off I tried to start again, just cranked along. Turned key off and back on - 0 psi on LP gage. Thought LP went out, then realized I had just tried to start it so the LP wouldn't kick on. Turned key and it fired right up? Only thing I noticed the CEL was on. I'm trying to figure this out and notice the tach bouncing from idle (800) back to 0??? WTF?! I increased rpms a bit and the bouncing stopped, then I noticed a strange sound from the engine compartment - kind of a low blowing sound - hard to explain. I put in gear to pull forward some and get under a soffit light in hopes to pop the hood and inspect - then the noise stopped. I checked all the turbo hoses day before when fueling up? I'm stumped - truck runs fine no loss of performance etc. I disconnected the batteries last night with plans of checking all grounds (especially on the PTS noise filter for the APPS), engine to body, body to frame, clean IAT sensor, and reprogram APPS.
Any ideas??? I'd hate to post on 911 as I'm not in dire straights yet.
Happy Holidays to you and yours.
Joe Mc
Joe Mc
