Check Engine Light & Tach Problems
Pyro readings?
Squeak While Turning Cured
Wiredawg
Fellow Rammers:
Truck recently started having the follwing symptoms: Start up fine, drive about a block and a miss, check engine light comes on, tach drops to zero and have hesitation 'til she warms up. Tach pops back up, no hesitation. At first, check engine light would clear, but doesn't any more. Get a P1693 fault code. Anyone got any ideas wuts the matter?
Thanks Wiredawg
P1693 only says a companion code has been set in both the ECM & PCM in the service manual. no help I guess.
check & tach
From what I've seen here when you have a performance problem and also lose the tach people generally suspect the crankshaft sensor. I think the manual has a troubleshoot table. I believe replacement isn't too many $$$.
Thanks y'all for the input. Gonna take my truck in and see. I'll post results here.
Take care, Wiredawg
