Engine/Transmission (1998.5 - 2002) check engine light
2nd Gen Non-Engine/Transmission A/C Sylonoid stuck?
Engine/Transmission (1994 - 1998) Fuel Heater
My check engine light came on yesterday on my 98. 5 24 valve.
It has fuel pressure-16 lbs. on a 16 lb. gage,oil pressure,voltage seems fine. .
To read codes on a 98. 5 can I use the "key" or do I need a reader?
I believe you'll need a code scanner on the 98. 5.
Once you know the codes, post back here and we'll try to help you out.
Regards,
John L.
