Check Engine Light?
Fuel pressure gauge install,how hard is it?
5 spd trans Shifter?
I have a friend that left his key turned to on with the radio playing while he took his ez off of his truck. This caused a check engine light to come on the dash. Will leaving the battery disconnected for a while reset the check engine light?
Thanks
after the third or fouth start it will "reset" itself... to clear the memory of the 'puter [pcm] disconnect the batteries and it will drop the code out... it will stay on the ECM though
I think you have to drive it a few miles and do the on/off thing with the key. Just switching the key several times didnt do squat until I put it in drive and went around the block and tried it a few times. I didnt even have to undo the batt.
