Well if the hanger got ripped out of the spot it was... I wouldn't put another hanger in the same spot. You can normaly tell if you need more hangers as the exhaust will be wiggiling around. How are your hangers mounted to the frame, are they directly bolted to the frame? Or do you have poly or rubber mounts for them? Also a suggestion, I put a piece of flex about a foot long in my system to allow the pipe to move around a bit under torque and load. The flex with the poly hangers give it enough movement to prevent any breaks, but not enough to see the pipe wiggilin around.
