Engine/Transmission (1998.5 - 2002) Check out these Fuel Pressures
Engine/Transmission (1998.5 - 2002) Transmission (Rear) Seal
2nd Gen Non-Engine/Transmission Emergency brake adjustmrnt
I installed a fuel pressure gauge this morning. I went off the fitting at the back of the filter housing, with Genos hose. Truck idles at 8 psi, at about 1900-2000 rpm it goes down to about 2 psi. Does anyboby have a Carter's part number for the lift pump. I thought I might check a local truck parts dealer to compare a price with that of the Cummins Service center.
I got both of my pumps, the regular one and the pusher from jannettys
Fuel Pump and wiring from
Jannetty Racing ent.
www.jannettyracing.com/diesel
CAR-P4601HP 14 psi electric FP $119
CAR-P4600HP 7# 100 GPG Pusher Pump $119
JRE-P4600HP Pusher pump wiring kit $34
JRE-P4601HP Lift Pump install kit $50
See here a diagram of my system on what I did to make it more reliable and not fail.
With this setup, I adjusted the regulator so that it read 14 psi and when I tow, it don't go down below 12. In the diagram, I forgot to put in the stock filter. it is there, just forgot... This makes all the pumps have a small head pressure even the pusher pump.
Here is the part number of the carter pusher pump from Summit racing- phone number-1-800-230-3030
CRT-4600HP 7psi -$75. 95
CRT-4601HP 15psi -$85. 95
