Check out this RIG
Front brake rotors
Dead 6th Gear
Found this sweet rig on E-Bay check it out
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=576314838&r=0&t=0
1997 Dodge Ram 2500 HD / Club Cab, Cummins Turbo Diesel (silencer ring removed), 4. 5" Skyjacker class II Double Flex suspension lift, 36x14. 5"x16. 5" Ground Hawg radial tires on 16. 5x9. 75 Weld Super Singles, dual steering stabilizer, 4. 10 gears, 33-tooth Speedo gear, Psycotty Air Induction, Mag-Hytec rear, Rhino liner, Extang Black Max, Grizzly double bent nerf bars, Bushwhacker exstenda fender flares, Kanduco Sweet Tooth grill insert, Confer super skid axle truss, DT Trac-bar, Moog tie rod system, Fabritech stage II traction bars, Energy sway bar bushings and end links. Truck Pic's
Oops, been lifted. Ye ol 10' pole thing.
Money Sink - 96, 5 speed, TST 380, HX40-16, 300 HP Injectors, Scourge BD 4200rpm Governor kit, McLeod, 4", CATless, straight out back, chrome turn down, ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Mag-Hytec, 3:54, Michelin 235s on Alcoas, Rancho 9000's, Valentine One, Garmin.
Dutchmen 27' 5th Wheel.
GoldWing.
