Engine/Transmission (1998.5 - 2002) check valve location needed
Can somebody tell me where the check valve is located on the VP44 and also what does it look like? Thanks, ben
heres a blow apart..... if you can find it here more power to you
This was at a shop in Las Vegas in '02
location of check valve
The check valve is located in the front banjo bolt/fitting that feed the VP-44. If you remove the bolt/check valve be careful not to drop the two gaskets (inner-outer). It takes a 19mm - 3/4 wrench. They make 2 types, one that can be taken apart and the other can not.
Alan
