checking fuel pressure
14cm wastegated exhaust housing
Setting the EZ with injectors
i received a fuel pressure adapter from tst and i am going to check my fuel pressure. question: does this adapter go on the forward banjo bolt on the top of the fuel filter? thanks. scott.
Yes, with a copper sealing washer that should have been included with your adaptor. It doesn't need to be very tight, you are threading into aluminum.
