Does anyone know if there's a way to check the lift pump for internal leakage once it's been removed from the engine ??
As i said in an earlier post, I'm getting diesel fuel in the sump. most of you say there's no way for the Injector pump to put fuel into the sump other than having a bad injector or injectors.
The only other piece that bolts to the block where there's an opening for fuel to get to the sump would be the lift pump.
