Ok you guys from the front end shops, here is an easy question:
With all the worn out trac bars I have read about I decided to check mine which was replaced 30 k ago. I had the wife move the steering wheel back and forth while I was under the truck. I notice up and down movement of the ball joint but not side to side play. Is this normal or do I need to order lukes links??
