Engine/Transmission (1998.5 - 2002) Chirping noise...
2nd Gen Non-Engine/Transmission Rear wheel shudder
Engine/Transmission (1998.5 - 2002) Code 1693
Chirp at idle at the exhaust tip - constantly chirping- is the turbo spinning roundy roundy. the belt chirp is only when you shut of and the belt catches at last second on the fan pulley.
If you don't run a OEM air filter it will be more prevalent.
Andy
