Chrysler and Getrag building gearbox plant
NOTE! Current flash is a REVISION!
Oil Level
From Fleetowner online newsletter
Jun 19, 2007 10:55 AM
A new $530-million factory is being built jointly by Chrysler Group and Getrag Transmissions Corp. in Tipton County, IN, to build dual-clutch automatic transmissions for Chrysler cars and light trucks.
Getrag describes itself as the largest independent automotive transmission manufacturer worldwide and is headquartered in Untergruppenbach, Germany.
“Dual-clutch transmissions (DCTs) provide much better shift quality, driving comfort, and superior fuel efficiency compared to more conventional technologies such as torque converter automatics and/or CVTs,” said Ulrich Kohler, Getrag’s vp-manufacturing.
“DCTs replace the energy-sapping torque converters of conventional automatic transmissions with two wet or lubricated clutches – one that engages first, third and fifth gear and the other that engages second, fourth and sixth,” he explained. “As a result, the transmission can deliver a 5% to 10% improvement in fuel economy. ”
Getrag will handle “operational leadership” of the plant, which will employ approximately 1,050 full-time Chrysler UAW-represented workers and 120 management employees from both companies, Kohler noted.
Construction on the new 804,000-sq-ft plant is slated to begin this month. The plant is projected to produce 700,000 dual-clutch transmissions annually when it starts production in 2009.
This new transmission will be behind a 6. 7L(2007. 5+)..... :rolleyes:
Where do you get your information? Maybe within the next five years, but I doubt they're going to start with the big transmissions, especially since they just came out with the 68RFE. From what I've read, the first DCT will be designed to go in FWD cars and behind the "Phoenix" V6, not the 6. 7L ISB. Chrysler Jumps on the DSG Bandwagon - AutoSpies Auto News
It was this part "... and light trucks" that was mentioned in the article in the first post. As much as I love my two Rams, they are classed within the industry as light trucks.
Anyway, if anyone has better information, I for one am interested. :)
sweet those trannies should lay some pretty fast et's. they way they describe it it sounds like the same style transmission used in the ferraries and bugaties.
I'm not going to pretend to be an authority on the matter, but everything I've read indicates to me that, initially, they are building a DCT for the FWD vehicles. That transmission would be a totally different layout than a RWD, let alone a large "light truck" transmission. They will get there eventually, I'm sure.
That's why I believe this thread belongs elsewhere. Plus, it's a very non-specific news release.
Depends on whether the Feds decide to apply CAFE standards to 2500-3500 trucks, that would be an incentive to get them in sooner, but otherwise it would take 5-10 years for the present new design to be shelved.
