Cleaning AFE filters
turbo for 03 with smarty jr & edge juice
Help! Leaking Fuel Filter Cap
I have 2 HEAVILY soiled AFE stage 2 PG7 filters. They are both black and I can't get them to even lighten up a little bit. Is there another way other than the manufactures kits for cleaning these filters?
Has anyone heard of a true flow XDi air filter system? They have them for our trucks but I have never heard of them. So far the best thing I like about them is that they are oil free.
The PG7 filters are about $100 a piece last time I looked so I would like to keep the two I have but I think my milage is suffering from the clogged filters.
Thanks
Jeff
Castrol Super Clean mixed 50/50 will degrease just about anything. Use same as filter cleaner. If you can see light through the filter then clogged is not your problem. I use the overboot & keep it rinsed
i soak mine in a tub of water with Dawn dishwashing liquid in it... about 30 minutes in warm water does it... . a few times it took 2 soakings... the cleaner that comes with the filter is junk... I could get it cleaner by pi$$ing on the filter :-laf
After messing around with all crap asst. w/ cleaning my afe- I called a diesel shop here in Omaha and they clean and re-oil it for $5 a pop. I can't complain as the filters look like new and I "trust" that they have been re-oiled better than what I could do at home.
I too had a tough time cleaning my AFE filter with their cleaning product. I had some K & N cleaner and tried that. That did the trick. Will try some of the methods listed here when I run out of the K & N cleaner.
Ken
