Hi everyone. I got myself into a little trouble and can use some help. I was installing the 'Rock Solid' steering column bushing on my 95 Ram (which was a complete nightmare to install with less than desirable results) and accidentally rotated the steering wheel in the column. My intermediate shaft was frozen so I had to cut it in half to remove it. In the process of cutting it, the steering wheel turned 180 degrees and locked. My problem is I don't know which way it turned. It could end up being 360 degrees off when I install the new shaft. Is there anyway to find the center position of the clock spring? Will I be ok even if it has turned 360 degrees? The last thing I want to do is change the clock spring. Please help!
