Done
The clock spring install went just as described - thanks!. I had to brew up a way to turn my 3-paw puller into a 2-bolt puller to get the steering wheel off, but other than that it was cake. The servo was easy too - the only problem being having to take the driver's side battery and battery tray out to get it in.
For those of you who don't know the history of this, I've been trying to figure out how to add cruise to my '02 HO/6-spd truck that came without it for months. I got absolutely no help from anywhere on how to do this, with 2 dealers telling me that an aftermarket unit was my only choice. My dealer even said that you couldn't get cruise on a manual truck! One helpful TDR member said he'd had a parts counter guy help him piece together the oem parts to add cruise, so I called a couple places. Finally the parts guy at a local dealer found a complete oem kit that was listed for my truck, so I ordered it. I was skeptical about it working as this same kit was available at an online parts place, but the guy said that it wouldn't work on manual trucks. To my surprise and delight, it works perfectly, and even though the kit instructions said you'd have to reprogram the ECU to get the dash cruise light to work, even that works! The only thing I have not tested is whether or not the cruise deactivates when you press the clutch. All the wiring was on the truck already, and it was just a plug-n-play affair.
As they're prone to say 'round these parts - Wicked Pissah!
