First off, I have a 96 2500 4x4 cummins/5 speed. I bought the truck a couple of months ago. At the time, the air bag light was on, and the cruise control didn't work (cruise light on the wheel would come on, but nothing else worked). I naturally assumed the clock spring was bad. Today, I put a new clock spring. Air bag light instantly went out. Great!! Then I drove the truck about 100 yds. and the light came back on. Took the truck out on the highway to try out the cruise. It seemed to work fine for about 5 seconds. Then the pedal went to the floor. Cruise is real eratic. It will give full throttle, then be normal, then no throttle, then full throttle again, all in about 10-15 seconds. I took the clock spring back out, and I'm trying to do a continuity test on it. At the airbag, the plug has three wires but only two pins in the connector. At the other end (down under the dash) there is two wires. The two wires at the bottom have continuity with two of the wires up top, but I get nothing out of the third. Anybody have any ideas what these readings are supposed to be like? And if it checks out fine, and ideas on what might cause my airbag light to come on and my cruise to not function properly?
Thanx for any help you can give me.
Trevor
S&N Fab
Trevor
S&N Fab
