I think I have a bad clock spring. Air bag light comes on, shuts off and 1 second later it is back on for good. Going to the dealer this afternoon to get diagnostics run. Sixty big ones just to find out what the problem is. If it does turn out to be the clock spring, are they hard to replace? Are they expensive? Thanks in advance.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Amsoil foam air filter and synthetics from nose to tail.
Cummins Power, don't leave home without it
