Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Clock work springs
E-Bay First-Gens
Cruise Control Not Working
To all 1st gens, I have found a good way to repair broken clockwork springs that are broken inside, If they are not broken in too many places I can repair them. If you want more Information feel free to ask .
I have been working with flex-print wire for years, if it isn't too damaged I can repair the flex-print wire. I did it to mine to test the process and it has been working with out a glitch for 400 miles so far. Flex-print wire is what is inside the clock work box.
I cant promice that every one can be repaired but I suspect that most are only broken in one place, so they can be repaired. But if the flexprint has rotted to nothing the whole cable must be replaced..... I am working on that part :) . I couldnt find a replacement :{ so I decided to find a way to repair mine and pass the help along Oo. Oo.
