2nd Gen Non-Engine/Transmission Clunk in the steering???
Engine/Transmission (1998.5 - 2002) Parameters for 2002 gauges
2nd Gen Non-Engine/Transmission Track Bar problem
OK heres the deal... .
Whenever I take a left corner at anything more than a couple mph, there is a knock from somewhere in my front end and for the life of me I can't find it. :mad: ONLY when turning left at speed. It seems like it does it while turning the wheel only past a certain point... like a hard corner or something. It's not a hard shudder or anything, just a very audible clunk.
Any thoughts or suggestions?:(
Will
idea on clunk
It's possible that the clunk is from the front track bar, which locates the axle side to side. If you do a search for track bar discussions, you'll find as I did that the bushing which mounts to the axle on the front in a small bracket can go bad or the ball joint which mounts to the frame on the other end.
I think the guys were saying that Napa stores offer their own or a MOOG improved part for just under $ 200. How many miles on your rig ? Do you drive street or off road or rough roads ? These are all factors, of course.
I'm just about to have installed a Rancho Suspension 2" lift kit that has new trailing arms with urethane bushings, and we'll get a good look at the track bar then, and if it's bad or going bad, I'll grab a new one. I suspect so 'cause I've heard a clunk occassionally from my front end, also...
Happy Dodge-ing !~
David B.
Well... . to clarify things... I am a 4x2 vehicle and I never see more than a rough road and I don't drive it hard... much:rolleyes: thanks for the help!
Will
