I have one that baffles me. My 4 wheel drive seems to work perfectly except after shifting out of 4x4 into 2wd I drive for about a mile and I get a clunking noise and sensation that is similar to the rear end clunking. It is not violent but it never used to do this. I had the tranfer case rebuilt last summer after a snap ring broke and except for this it seems to work well.
The truck will shift into 4x4 hi range just fine at speeds up to 60. No clunking just slips right into gear. It doesn't whine anymore than it used to and the indicator light comes on almost immediately. I will drive for a mile on the interstate and shift it back into 2wd. The 4x4 indicator extinguishes almost immediately and all seems well. After about another mile of driving I get the afore mentioned clunk/sensation. Sometimes it is very pronounced, but not violent, other times it is almost imperceptable.
I was under the impression that when the light went out the axle was definitely disconnected and the front output shaft from the xfer case was disconnected when the lever moved. If this is the case I am stumped! It has done it in both 4th and 5th gears so it doesn't seem to be the transmission.
Any ideas would be appreciated. Anyone else had this problem?
