Engine/Transmission (1998.5 - 2002) Clunk when braking
Engine/Transmission (1998.5 - 2002) 1998.5 and not a 53 ??
I have this clunk when braking that sounds like it is coming from the rear brakes. Any thoughts or ideas as to what this might be. It seems to happen a couple seconds after I step on the brake pedal. I know it is not diesel sloshing around in the tank, it is definately a clunk you can hear and feel when you step on the brakes.
Mike L.
I'm sure you've checked everything you can think of, so I'll throw out something that can get overlooked. I have seen the brake backing plate move relative to the flange on the axle tube. The bolts may still be tight, but don't have enough clamp force to prevent a slight amount of movement when braking. Lots of possibilities though - suspension, brakes, spare tire... Good luck.
