clunk when turning to the left?
Front driveshaft u-joint lube?
Problem with VIN numbers need help
Have 2" level blocks with slight clunk on right hand turn when installed. After plowing one storm I know have a load clunk to the left all the time. Checked all bolts, turn wheel and it won't happen. Only happens at forward speeds. Wife won't hang off front bumper to listen. Maybe get her into shopping cart and push it. :-laf I did give her a good xmas present.
Any ideas before I take to front end shop? I have had it aligned seeing all the problems people have had after. Tires have worn correctly so far 10k since installed.
Thanks for any replys.
