I have this clunking noise under the truck whenever I hit even the slightest bump on the road. I replaced the rear sway bar links with the Max links from Geno's because the old ones were worn out. That took care of half of the noise, but now I can feel something clunking under the truck near the front end. I already checked the front sway bar links and other bushings in the control arms. Did I mention It's 4 wheel drive to.
Im running out of options since I cant find anything loose.
PS Does any body have advise on some good shocks aswell for this truck,I currently have the yellow Bilstiens, which only lasted about a year.
98. 5 Ram 3500 4x4 sport,Auto trans,3. 54's autometer,sport comp pyro,trans,boost,electric fuel press. w/snubber,warning light/chime. edge comp drag box,2nd VP-44 inj. pump,carter pusher pump,dual fltr. amsoil. Suncoast converter,valvebody,Built by Inglewood Transmission,allum trans pan, Bilstien shocks,westin bars,push bar,custom 5" exhaust,BHAF, Silencer ring is where It's needed(at EX'S House).
