Dave, Where do you tie in the switch?I have a 05 six speed and I was not sure when the fan came on full. The Ac would make it come on but not full. I add a switch to make it come on full and you can hear it come on and it is full on. I only use on long fulls when the temp get above 214 and leave it on a minute. It does bring the temp down, when it goes up again I turn it on. I am pulling a 15k fifth wheel. I understand that there may be a SB to fix the problem. I don't want to take mine in.
Dave Mc
The early trucks would need to have an ecm flash to have the fan run with the ac... mine never had it, and my ac works just fine.
The flash came out in 05 if I remember correctly.
Your Smarty Jr now gives you that re-program.
My AC worked just fine prior to the Jr, but that was for only 190k.
