There's a couple of threads here related to failures of automatic transmission flexplates - the plate between the friction materila and hub on a standard transmission setup is pretty much the equivelant. The material used seems to be some sort of spring steel looking stuff, and not REAL thick or hefty at that - nor do the securing rivets appear to be terribly rugged...
SO, how often do these fail - sure don't see many reported here - and does anyone know what the actual torque rating is for a stock-based clutch assembly? For the record, some (maybe MANY!) aftermarket outfits seem to use the stock hub, flexplate and base hardware as the starting point for their "high HP" clutches - but like a chain, the best clutch going is no better than its weakest point...
