Archived Clutch help
Archived Auto Trans Shops
Archived leak where fuel line connects to injector box
Need some help guys... . I was coming home yesterday, went to make a left turn and when i pushed the clutch, the pedal went to the floor. As of now the truck is in gear, i was able to drive it home slip shifting all the way(stop signs were fun!). I think it is the slave cylinder, master is full of fluid and i see no leaks. The pedal still goes right to the floor, no resistance. Any help would be appreciated!!! By the way... truck is '01 ETH... see sig... .
If the slave cylinder were bad you could pump the fluid out of the master cylinder. In that case, should see a leak and the master cylinder level would go down. Either the master cylinder is bypassing inside or something at the slave cylinder/linkage has failed or come loose. bg
Thanks for the reply. I found that it was the master cylinder bypassing. Put a new one on this morning and everything works like it should again.
