We got everything torn apart on the 96. No wonder it would not move. The rivets holding the hub were torn out of the disc. I read on the disc or pressure plate that it was a Luk clutch. I am guessing this is a replacement clutch and pads on disc were about worn down to rivets. This truck has 170,000 miles on it. I suppose this truck could be on the second clutch, depending on how the previous drivers treated it. Should I be checking out condition of transmission, since it is sitting on the ground? I need to install the bigger input shaft for the Southbend dual disc. Going to replace seals, but did not know about syncronizers. How many miles are the NV4500 normally good for? I know about the 5th gear nut, but do not have any knowledge if this has been done. Any thoughts? Thanks.
