It's not a fun job without a lift, but I've done a few autos and manuals on my back. You'll need two 3-ton jackstands at the minimum, and a cradle can be bought to fit in the top of the floor jack, but that's a dangerous way to do it(no means of strapping the transmission to prevent tipping). See if you can rent a low-boy type transmission jack over a weekend, that would be safer.
A port-a-power hydraulic ram is nice for spreading the frame rails, easier, quicker, less frustrating than hammering on the crossmember to remove it. Tip: Work the crossmember towards the FRONT of the truck, it'll come out easier that way.
You'll need something stronger than a Craftsman 8mm socket for getting the u-joint strap bolts out, preferably an 8mm 6-point box end wrench, AND an 8mm impact socket. Tip: grab a can of "PB" spray from AutoZone, spray it on the bolts before you start, that'll help loosen 'em up.
Oh, yeah, one other thing, run a search, this website has a GREAT search engine, there's other threads chock full of great advice and step-by-step how-to's on clutch installs !!! Even with pictures!
