Just completed the installation of a South Bend SDD3250 in my 03. I just wanted to give some feedback to the community. The installation was done with the use of a drive on lift and a heavy duty trans jack. My co-worker and I completed this in just under 5 hours. The rear drive shaft was completely removed and the front disconected from the transfer case. Shifter was removed and bell housing was unbolted. There is a bracket on the bellhousing that is a anchor point for the exhaust down pipe. We spun this around and removed it from the front. The starter and the exhaust did not need to be removed. The crossmenbers were then removed and the transmission and transfer case were lowered and pulled back from the engine. The clutch was installed per the provided instructions. It is a must to get the alighnment tool to slide in and out without any resistance. We also removed the washer behind the pivot ball for the throwout brearing arm. Everything was re assembled and a new HD hydraulic master and slave cylinder were installed. The pedal pressure is the same as stock in my opinion if not better. The clutch is a bit grabby but I expected that. The noise is noticable but also not bad. All in all I am very happy with the clutch and the ease of installation. South Bend has really done there homework. I hope that this post is of some help to anyone looking to instal this product.
