Archived Clutch interlock problem, or maybe not?
Archived broke down 09 6.7... shut down
Once again, my truck will not start. When I put the key in, the radio and accessories come on. When I turn the key, nothing happens - no starter, no anything.
I figured it was the clutch interlock, so I got some wire taps and tried to bypass the safety switch. The clutch interlock switch was loose and rotating around the master cylinder rod. However I still could not start the truck.
What do I need to do next? Is there a trick to bypassing the interlock, or is there a fuse/relay somewhere I should check?
I figured it was the clutch interlock, so I got some wire taps and tried to bypass the safety switch. The clutch interlock switch was loose and rotating around the master cylinder rod. However I still could not start the truck ?
Loose and rotating, normal. The white retainer can be removed easily, pull body up and snap off of rod. Can be inspected and cleaned checked.
iPad typing, strange!
Gary
