Well the 2001. 5 5 speed slave cyl went out at 118,000 mile i thought,it turned out to be the clutch master cyl that was bad,after replacing both of them,old style of course and bleeding as much air out of the closed system as i could,it was still not right (air) So i came up with a brain storm and it worked. I drilled and tapped the black cap 1/8 NPT (and removed the black rubber bladder under the cap)and hooked up a hand vacuum pump and 10 hg of vacuum air was coming up through the fluid,so i took it to 25 hg of vacuum there was small bubbles,i left it on there for 10 minutes. All is well on the closed hyd system now.
