Ok this should possibly be on the conversion section but lately there is no one on it nor does any one answer and its concerning a gen 1 truck build . On my 85 build im doing i might have ran into a snag but i need to do more measureing to confirm it . On the fire wall the electricle plug is in a diffrent location by a inch or so . So im thinking this is going to come into play with the clutch master cylender . So i have a question or two that i need help with .
1. Does any one know if a gen 2 clutch master cylender will work on a gen 1 truck ? , does any one know the the with of the mounting plate and what type of renforcement inside of the cab is needed ?
i think a 4" square plate inside of added material would fix this .
2. other question on the gen 2 trucks 94 to 981/2 are the wireing plugs smaller in size , i know there is 2 or 3 on the gen 1s that are the same but im more so refering to possibly get rid of the large square wiring block since the engine im going to use is a 94
3. does any know and or have a gen 1 inside cab clutch master cylender mount some one welded the one i got so that one is useless now
