clutch master/slave cylinder
the HX 40 is back at home
Probe tip melting off?
For the past few days, my truck has been trying to run over small import cars. I think my clutch cylinder is going out. The manual makes it look pretty easy to change out as a unit. Anyone changed one? Are there any unforseen land mines to be aware of? Special tools? Best price in town? At least it's plastic!!!
98 2500 CC SB 4X2 12v 5spd 4. 10, -silencer, AFC+20, Edelbrock IAS, VDO gauges, Reese 15k Classic
97 Dodge Stratus 150HP
92 Harley Fatboy, Dynojet fuel management, Supertrapp 2-1
00 Jayco 25' 5th wheel, single slide
1 what are the miles on your rig???
2 Can you shut off the eng and depress the clutch and go thru the gears?? One by one????
I have 78,000 on it. It shifts fine but when I'm holding the clutch waiting for a hole in traffic, it'll start to pull. Then when I start to let the clutch out, it's already most of the way engaged. It's definately the master or slave cylinder bleeding back. It could get dangerous so it's parked until I can get a unit and replace it. It looks simple to change but you know how looks can be deceiving.
