took it all a part, this squeeking clutch pedal is driving me nuts. it is not the pedal for sure. there are two pivot points, one for the pedal and one for the rod the pushes the cylinder. both had plenty of lube and without the rod connected the pedal makes no noise and moves smooth. if you push the rod in by hand , it makes the noise. so we can rule the pedal out.
