Hello All,
I recently got tired of having to push the clutch pedal all the way to the carpet to get it to dis-engage. It was bad enough that I had to twist my boot and go pigeon-toed to even be able to shift. I realized there's no adjustment for this hydraulic system, so I started checking other things. I noticed that when the clutch pedal was at rest, it had about 2 1/2" slop swing. As I checked, I noticed that the slop was all in the connection of the master cylinder rod to the pedal pin.
Well, as a true professional crastinator, I decided that I could just be pigeon-toed for awhile. This job would require pulling the whole pedal and the master cyl. I just brushed it off until sitting in traffic one day. I thought what if that dang pin wears thru and breaks? Uh-oh... . The next weekend I got on it and fixed it before it did. Pulled the pedal and master, welded, filed, fitted new bronze bushing, and Holy Cow! I'm one happy camper now! The clutch is fully out at 2 inches-plus off the carpet! I'm starting to walk normally again... ... . :-laf
I'm posting a few pics of the worn stuff as it came out. I'm so glad it never broke.
Something you may want to check if you feel slop at the top of pedal swing. I never thought it could be this bad at 175k miles.
