Originally posted this as a transmission problem some days ago, but now believe it to be a problem with either the clutch master cylinder or slave cylinder. (Ken put me onto this on a 7/9 post. )In addition to being difficult (nearly impossible) to get into reverse and granny low, if I am stopped at a signal light while transmission is in first gear with the clutch fully engaged, after about 15-20 seconds, the truck starts to creep because the clutch appears to self-engage. If I put on the brake to stop the creep and do not take it out of gear, it will eventually lug the engine to a stop. Does this sound like one of the cylinders is dying? If so, which one? Do both have to be replaced, i. e. does the part come as a unit with both cylinders or can you buy them individually? Anyone out there with experience in this matter? Any help you can offer will be appreciated. Thanks in advance. GC
