Hey Fellows,
I got a question for you mechanics out there. My 95 Silverado 4x4 has a chattering clutch problem.
I have replaced the following:
Disk
Pressure Plate
Throughout Bearing
Pilot Bearing
transmission Mount
Resurfaced the Flywheel
Rear-Main Seal
The strange part it is that it don’t chatter to bad when you first run the truck, but after 30 minutes of driving, it chatters badly. The whole truck shakes bad when you pull out. Something else interesting is the clutch pedal makes a bad squeaking noise when the motor is warmed up when you push it in. When the motor is cold, it doesn’t make any noise at all. This is my daily driver truck (until I buy another Cummins next spring), so I need to get this fixed. I’m hopin its a cheap fix since I’m a poor college student.
Items I *think* might be causing the problem are:
Bad Slave or Master Cylinder
Bad Clutch Fork
Over-ground Flywheel Surface.
I am open to any suggestions, and very much appreciate any help. Thanks a bunch.
Brandon
Disk
Pressure Plate
Throughout Bearing
Pilot Bearing
transmission Mount
Rear-Main Seal
Bad Clutch Fork
Brandon
