I have a 2004 6 speed manual transmission and pull a 31 foot 5th wheel. After about 5,000 miles, I started noticing that the clutch would chatter when I tried to back up with the 5th wheel attached; this was particularly evident if I was backing up a slight incline. Dodge finally replaced the clutch under warranty at 9,000 miles, but now the problem is no better and may actually be worse than before they changed the clutch.
Has anybody else had similiar problems with their clutches? Any ideas what could be causing this problem? (The Dodge mechanic told me if the clutch didn't also chatter in first gear[it doesn't], that it wasn't the clutch?
Thanks for any suggestions. JMVincent
