It's been quite a while since I had three pedals so bear with me. I'm looking at a couple of used 6-speeds to test drive this next week, and want to know what I should look for regarding worn clutches. These would be on 3rd gen trucks. How can you tell if the clutch is slipping? Is there some type of test I can do to check? What else should I listen for when I take it for a test drive? Driveline vibration? Can you feel it in the steering wheel?
One of the trucks, which I'll probably pass on, but will drive anyway, has had a turbo assembly replaced at 6100 miles, and U-joints replaced at 32,000 miles. What would be the reason the turbo failed so early? Anything else I should look at when I check the trucks out?
Thanks
Paul
Thanks
Paul
