Engine/Transmission (1994 - 1998) clutch replacement
2nd Gen Non-Engine/Transmission Clunk
Engine/Transmission (1994 - 1998) Engine will not crank.
Its time to replace my clutch and I am looking for some input. I am not sure if the clutch I have matches my signature or not. I bought the truck from a former member who I am not in contact with anymore. I copied his signature and pasted it to mine. I do know that he replaced the clutch right before he sold me the truck. I am currently looking at the south bend sdd3250 on extreme diesel.com and was wondering if this clutch is a good fit for me. I don't haul often, but when i do it is usually 2 horses with a total weight o approx 7000-8000 pounds with trailer. The clutch i am looking at comes with a flywheel and offers a heavy duty hydraulic package for a few bucks extra. I have changed the trans on this truck(nv4500), but never messed with the clutch. This will be my first clutch replacement so I was wondering what to be prepared for. This kit says that it will require a 1 3/8" input shaft upgrade. Does this mean I will have to take the trans apart to do this? Maybe there is a better clutch for me. Any input would be helpful. Thanks
The cono clutch will work just fine for this truck, Does the truck have a 13" flywheel or 12 1/4" if it has the 13" you need a 1947-O clutch if its 12 1/4" you can upgrade to the 13" with a 1947-OK which includes the 13" flywheel these are South Bends #s
Hope this helps
If it is a 215 HP engine, the #10 plate fully forward wil give 370-400 HP, 900-1000 ft-lb, and egts at or over 1600 degrees. You need more turbo, or move the plate back .090" at the minimum. As for the clutch, the con-o probably won't hold. The con-FE should, as should the double disc clutches from South Bend.
Reading what you have said it sounds like you already have a 13 inch P-Plate and Disk. You also have a 12 1/4 flywheel that is drilled for the 13 inch P-Plate. So really all you need is a new disk and p-plate throw out bearing and pilot bearing. Probably need to resurface the flywheel. Save yourself some money and forget about going to the 1 3/8's input shaft. I would also go to the South Bend CON-O disk with the 10 plate all the way forward. You should not need to up grade the hydraulics with this set up but you can if you want.
I am not sure which flywheel I have. I am still driving the truck right now. Just want to be as prepared as possible to minimize downtime. I will drop it down and post back. It may take a little time. Thanks for the help.
The five speed design flywheel has the ring gear away from the starter such that the starter is bolted directly to the aluminum block adapter plate. The HO 6 speed flywheel has the ring gear closer to the starter, and will have a spacer between the starter and the block plate, 9/16" thick, up through 2002. In 2003, Cummins began using different block plates for HO stick and auto, so the plate itself has a raised pad for the starter.
