First gen is Sachs 13" diameter. Second gen 5 speed clutches are 12. 3" LuK with the same bolt pattern and splines (1. 25 x10). In my experience, the Sachs is a lot beefier, lasts much longer, holds more torque. First gen indexes on a lip at the outside of the flywheel. Second gen uses small bolt holes in the cover, first 3 threads cut out of the flywheel, and shouldered bolts.
