Clutch slave cyl.
Recommended Exhaust System - 2007 5.9
Cp3 pump gearcase timing 04.5
I read in one of the previous issues about replacing the slave and master for the clutch in my 2004. 5 and I didn't do it when I put in the new clutch. That was about 15,000 miles ago. Now, every now and then the clutch won't completely release. Kind of a problem at a stop light. Issue number and suggestions. No leaks and full of fluid. Thanks Eric
Mine is starting to do this a bit too. I'm going to try the bleeding since that old discolored fluid can't be working like new any more.
I see on the South Bend website that they recommend installing their HD master/slave system with a new clutch but my installed didn't bring it up. That was about 35K ago.
Anybody know what the difference is between the stock and HD setup is?
