I put in my 3kgsk yesterday (wow) and slid the #11 full forward. AFC housing 3/4 forward and star wheel full rich. Yes it smoked too much and ill deal with that on another day. The truck has 3. 54 gears and 31. 5 inch tall tires. The reason for this post is I went for a test drive, had the truck in 4th gear at about 1300 rpm and pushed the pedal to the floor. The clutch (original with 50k miles) sounded like it was slipping. I got out of it, slowed down and repeated the test. This time watching the tac at about 1600 rpm the engine raced to 2300. I then got out of it and the tac dropped to 1750. It was slipping! I then drove the truck to my safe highway section to do a 4th gear run with my g-tech. This time the clutch held. I did it 3 more times and it held every time.
After the gov spring install I sprayed brake parts cleaner on the block under the pump to clean off the oil that came out. Do you guys think oil or parts cleaner could have gotten on the clutch. I dont understand how a clutch could slip twice then hold 4 more times under the same conditions. Thanks for any ideas.
By the way at 8120 lbs the g-tech showed peak 598 ft lbs at 1700 and 240 hp at 1900. Both rear wheel.
Bill
Bill
