Clutch Slipping
New Baby!!!
To Tim Allen : You Want a piece a'me?
What to do I have a 2001. 5 HO 6 Speed it has 11,234 miles on it and today the clutch started slipping and I meen it slippes in 4th 5th and 6th gears if I get over 1,300 RPM's it starts slipping. #ad
I have a K&N RE-0880 and 25-0880 cover and A 3" straight pipe no box's "yeat" I did not run on the dyno yesterday and I had NO clutch slip yesterday. What should I do? #ad
HELP
Thanks
Cliff
my truck http://communities. msn.com/isapi/acssrv.dll?did=1&action=homepage&commid=oasis320015&naventryid=100
2001. 5 Black Sport 4x4 Q-cab 6-Speed HO,3. 54 - K&N RE-0880 & 25-0880 - Towing & Camper Packages - Real Backup Lights - Fog Lights - Windows Fixed - Phord 4 Door Nurf Bars - Leveling Kit - CB - Electric Brakes - Class 3 Hitch on front - Cat & Muffler fell off - 285/75/R16 Interco Trxus 10 ply tires
Wow!!! I knew the OEM clutch was wimpy but this is ridiculess: #ad
. I would take it to the dealer and see if you can get it fixed under warranty. The mods you've done so far isn’t enough to slip the stock clutch, so I would surmise that there's something wrong with your clutch. My OEM clutch held with the Power edge on hot #3. Good luck #ad
2001 Driftwood 3500 Quad Cab 4x4, Long Bed, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE) Loven the shift thing (Arrrrrh), 3:54, SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, 18,000 LB 5th Wheel Hitch, Leather, Sliding Rear Window, BDs E-Brake, Rhino Liner (gray), Velvet ride shackles, cup smoothy, Power Edge box / EZ Box w/elbo, DD Stage III injectors, McLeod Dual Disk Clutch, K&N, SPA Gauges, Jardine Exhaust, 16cm turbo housing. Love the smell of diesel in the morning. Hope your watchen DC cuz every thing you see here is a big lie, Hehe.
Cliff, sorry to hear about your clutch and I agree with the above, get it back and repaired under warranty, unless you are going to add more HP in the future. If your thinking the latter, then go to A. W. D. for the Mcleod install.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Cliff, like posted above, get to the dealer and get it documented as to the slipping before the 12,000 mile mark. then as the dealer tries to figure it out let the milage roll.
Plus the fact I pull heavy quite a bit and have had no slip what so ever..... Pete
my clutch went out at 12,437mi it lost the lining on the pressure plate side. (defective) better crawl under it and look, I had pieces of the lining coming out the holes in the bell housing.
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's,PowerMax3 adj. , A pillar Boost/EGT,4" turboback exhaust,custom built aluminum airbox W/K&N-RE0860 through the cowl, 310HP/675ft-lbs and more to come...
Clutch is 12,000 mile warranty. Better hurry. Offer ends soon. Batteries not included.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
Up date I went to my local Dodge dealer yesterday and the clutch still slipped but not as bad service rep. took the truck for a ride and said the clutch was shot but did not slip #ad
So it goes in on Thursday the 17th to get a new clutch. Today I drove the truck and no slip the only thing I can think is I had the truck parked on a steep hill had to back up it in 4wd could some oil have leaked out and onto the clutch?
It's like the truck wants to fix it's self #ad
again Thanks for your help
Cliff
