Clutch Switch Kit
water temp - 170/180 or 200/210 range ?
Post your install pics
Found this on Cummins on-line:
Customer Login
Welcome:
Enter Site | Logout
Information
Related Links
Service Locator
QuickServe News
INSITE Support and Windows Vista
INSITE Tips from the Experts
Reminder of INSITE Operating System Support Change
INSITE v6. 5. 1 Product Announcement
Cummins INLINE 4 and INLINE 5 - Software Upgrade Announcement
Clutch Switch Kit for the Dodge Ram
Warm Up Faster With Less Idling.
When you need to warm up your engine, you can warm up faster with our Clutch Switch Kit. Designed for 2005 and newer Dodge Ram Turbo Diesels equipped with manual transmissions, the Clutch Switch Kit uses your cruise control button to provide the extra rpm you need. At the touch of a finger, you can increase idle speed up to 1500 rpm. This way, you can warm up your engine much faster with less idling and be ready to roll when you need to.
It's Even Better With A Jacobs Exhaust Brake®.
In a Dodge Ram equipped with a Jacobs Exhaust Brake, the Clutch Switch Kit performs even better, with even faster warm-up times. Once your exhaust brake is installed and turned on, the maximum engine speed during idle warm-up will be limited to 1350 rpm, but the idle warm-up capabilities will be significantly increased.
It's Easy To Operate.
Operating the Clutch Switch Kit on Dodge Rams with manual transmissions is easy. As with standard models, the warm-up feature is deactivated when the clutch pedal is depressed. Before putting the transmission into gear and driving, the driver must make sure that the feature has been deactivated and the engine has returned to normal idle speed. A quick glance at the rpm gauge is all that is required.
Supports Anti-Idling Regulation.
If you reside in an area that has idling regulations, you will appreciate the fact that your cab will reach warm-up temperature with less idling.
Every Benefit.
Faster warm-up with less idling
Easy to install by dealer
Easy to operate
Integrated with cruise control on steering wheel
Interfaces directly with Electronic Control Module (ECM)
Automatically deactivated when clutch pedal is depressed
Designed for simplicity and reliability
Does not affect engine warranty
Designed specifically for the Dodge Ram equipped with manual transmission
So why wait any longer? Ask for Cummins part number 408985100 (Mopar No. 05175417AA). This kit contains all the necessary components for installation. *
Warm up fast with our Clutch Switch Kit for Dodge Ram pickups. Every Time. For details, phone 1-800-DIESELS.
Jacobs Exhaust Brake is a registered trademark of Jacobs Vehicle Systems.
* Dodge dealer's electronic service tool is required to activate the Clutch Switch Kit.
Bulletin: 4081625
Page Last Updated: Friday, December 15, 2006
PRINT THIS PAGE | EMAIL THIS PAGE
© 2007 Cummins Inc. , Box 3005, Columbus, IN 47202-3005 U. S. A.
Terms of Use
