Looking for opinions & info on clutches. I have two 92 diesels with 5 speed trans.
#1 is a W-250 which I bought new, which has the original clutch- 265K miles.
it has a 13" clutch with cast iron diaphragm type cover, with a lip on the outer edge of the flywheel and a bronze bushing for the pilot bearing.
#2 is a D-250 which I bought used, (I'm 3rd owner). It has a replacement 12 1/4" clutch with stamped steel diaphragm type cover, a flat surface flywheel and a needle bearing pilot bearing. The clutch was replaced just before I bought the truck with "just a good quality O. E. M. equivalent replacement clutch, not anything super special" (previous owner quote).
Both clutches seem to work OK, except for a tendency to shudder when backing up an incline, on #1, the 4WD.
I've been using #2, the 2WD for some heavy hauling with a trailer out of Phoenix and up over Wolf Creek Pass in Colorado, with no problems.
One of the engines will be refitted into a truck with an auto trans, and the other to the 4WD , with a Getrag 5 speed.
Any opinions on why the difference in clutches? Which type/size should be best to re-install or as a new replacement?
Any preference/suggestions on replacement brands or type?
Pilot bearings. I'm partial to the bronze bushing type myself, any experience, good or bad, with these?
Guys, any and all comment or suggestions will be appreciated.
Thanks, Jack Dancoe
Thanks, Jack Dancoe
