The closest Dodge dealer with them in stock is 75 miles away. I checked on the ARP's, they don't have a listing for my truck. Joe's right on the 5/16-18. The longest they had was from a Ford application and they were about 3/4" long. I found some Mr. Gasket pressure plate bolts that are 1" long, no flange head, but they do have the shoulder. The problem is that I'm getting it put in Monday. Do you think the Mr. Gaskets will be OK?
HCanales, do you remember if the drive shaft length was the same as your auto? I have the front half of the manual drive shaft so I have the proper yoke. Will all I need to do is swap out the yokes or will I need some drive shaft work? Also, the hole in the floor for the shifter, is there one already there or is it marked in some way? I have a transmission tech doing it for me but he wants me to take care of the hole. I already have the pedals in. Man were they more work than I thought they would be!
Thanks,
Scott
