Clutch torque specs.
Gauges in.
Performance Question on '01.5 Auto
KPerkins
I need the torque specs for the flywheel and pressure plate bolts. Have everything ready to go together. Thanks for the help!!
torqe the flywheel to 101 ft lbs
the pressure plate bolts to 30 ft lbs
97 2500HD 4x4 ST 12v, K&N,16cm, 4" Jardine turbo to tail,Auto Wurks tuned pump,man trans filter, McLeod clutch, LSD with 3. 54's and Amsoil, AGR power steering box and pump, Borgeson steering shaft, Skyjacker 2" leveling kit, Rancho RS9000's, dual RS5000 steering stabilizers, AR Outlaw II wheels with 33x12. 5 Bridgestone Desert Duellers, Lund visor, Ventvisors, Glasstite HiRise cap, aluminum tailgate protector, illuminated bumper guide poles, Cobra CB, Wilson 5000 antenna, Alpine CD, Infinity spkrs, Fosgate amp with 8" Bazooka tubes, and Husky floor liners. 16. 247 @ 87. 52mph quarter mile at 6700lbs
Thanks Terminator!
Just installed a new South Bend clutch. The job was really straight forward, had no problems at all. Decided to change the transmission fluid while it was jacked up. Really easy to refill with the shifter off. Thanks again.
Ken.
98 2500 12v 5spd, 3. 54, K&n filter, BD cat back, dead cat, Schied Diesel tuned, South Bend clutch, 5whl& gn hitches, flow through tailgate. Lund running boards with lights.
Peter.
I purchased the MU 0090 fabric faced Clutch. Everything arrived in good shape. I had the flywheel resurfaced but opted to install a new stock pilot bearing. I didn't give the clutch much of a breakin, I backed it out of the garage and hooked it to my flatbed trailer with a 3000 lb. tractor on it. The clutch felt very firm as it engaged the load. Engaged and disengaged smoothly as we shifted through the gears. With no load, feels a little grabby while slipping, backing into a parking spot. I feel this may smooth out as it breaks in. So far very satisfied.
